U mnie dalej walKA z ABS aby zakodowac w nim PLA :(
1K0907379AJ
J104 ESP MK60EC1
13 11422012092600FE880C04EA901900513F0D00
Znalezione bledy
3075(0x0C03):68 Sterownik automatycznego pilota parkowania Sygnal niezrozumialy Lamp OFF
1K0907379AJ
J104 ESP MK60EC1
Znalezione bledy
A we wspomaganiu Park Assist zakodowałeś? Dokłądniej robi się to w kanale adaptacji 4:
Cytuj:
A004,0,Installation Park Steer Assist
A004,5,Installation Park Steer Assist
A004,6,0 = Park Steer Assist (PR-7X5/7X6) installed (< MY 2009 / PLA 1.0)
A004,7,1 = Park Steer Assist (PR-7X5/7X6) installed (MY 2010 > / PLA 1.5/2.0)
A004,8,2 = Park Steer Assist (PR-7X0/7X1/7X2) NOT installed
Tak w 44 zakodwane ADAPTACJA 10 kanal 4 wartosc 1
Wg rozpiski czaro PDC 10
U mnie jest zakodowane BYTE 01 bit 1 ,BYTE 02 bit 2
S00,Parking Aid (J446) Security Access
S01,71679 = Coding Enabling
LC,00,0~3,00,Trailer Hitch not installed
LC,00,0~3,01,Trailer Hitch installed (manually removeable)
LC,00,0~3,02,Trailer Hitch installed (electrically operable)
LC,00,4,Optical Illustration active
LC,00,5~6,00,Camery Type: Not installed
LC,00,5~6,20,Camery Type: Rear View Camera installed
LC,00,5~6,40,Camera Type: Environmental Camera installed
LC,00,7=,Some Options may require a Security Access before Coding!
LC,01,0,Automatic Transmission installed
LC,01,1,Start/Stop System installed
LC,01,4,Right-Hand-Drive (RHD)
LC,01,7,Mute Function active
LC,02,0~7,00,Control Module not coded
LC,02,0~7,01,Model: Audi A3 Cabriolet (8P7)
LC,02,0~7,02,Model: Audi A3 3-Door (8P1)
LC,02,0~7,03,Model: Audi A3 5-Door (8PA)
LC,02,0~7,04,Model: Audi A3 3-Door S-Line (8P1)
LC,02,0~7,05,Model: Audi A3 5-Door S-Line (8PA)
LC,02,0~7,06,Model: Audi A3 3-Door with Mobility Package (8P1)
LC,02,0~7,07,Model: Audi A3 5-Door with Mobility Package (8PA)
LC,02,0~7,08,Model: Audi A3 Cabriolet S-Line (8P7)
LC,02,0~7,09,Model: Audi S3 3-Door (8P1)
LC,02,0~7,0A,Model: Audi S3 5-Door (8PA)
LC,02,0~7,0B,Model: Audi TT (8J)
LC,02,0~7,0C,Model: Audi R8 (42)
Wie ktos moze gdzie podzialo sie menu w zegarach odpowiedzialne za PDC? Na poczatku mialem, teraz ucieklo I jest tylko przez rns-e?
A co kolegi wrclaguna to co nie dziala? Poziom trudnosci montazu tego systemu jest tylko troszke wiekszy niz wymiana zarowki wiec ciezko cos zle zrobic.
ja tam zadnego menu nie mam, chyba mylisz z tym co sie wyswietla podczas parkowania za pomoca pilota.
nie, chodzi mi o takie menu jak w rns-e, czyli glosnosc I czestotlliwosc
Przedostatni bajt na 0C jak ustawisz to powinien błą PLA zniknąć, ale wtedy może w sterowniku PDC się zaświecić jak masz wsadzony.
Jak tak zakoduje to zero błedow .
Mam mi.in. kabelek VAG CAN i jest tam procedura kodowania ABS ale niestety jest to nieaktywne :(
Jaki numer sterownika PDC I jakie kodowanie??
Czyli jak rozumiem jak w abs jest zakodowane PLA to wali bledem?
PLA nigdy nie dzialo, bez roznicy czy jest zakodowane w abs czy nie, naciskasz przycisk I zglasza awarie?
Sterowniki 44 I 17 poprawnie zakodowane?
