Pokazane rezultaty 1 do 10 z 11
Temat: 1970 Chevy Chevelle Turbo-Diesel - Biowarfare
    Małopolskie Szakall69's Avatar
    Oct 2008
    Kraków
    Służbowe
    151 razy
    70 razy
    Exclamation 1970 Chevy Chevelle Turbo-Diesel - Biowarfare
    By The Numbers
    ’70 Chevy Chevelle
    Mike Racke, 29 • Fullerton, CA
    Total cost to build: $250,000
    ENGINE
    Type: GM 403ci Duramax LLY turbo-diesel V-8
    Block: standard 4.050-inch bore production block
    Oiling: stock pump and pan
    Rotating assembly: stock 3.900-inch
    forged crank, Carrillo steel rods,
    and stock 16.0:1 pistons
    modified by SoCal Diesel
    Cylinder heads: CNC-ported SoCal Diesel factory
    four-valve castings fitted
    with stainless steel 33mm intake valves,
    Inconel 33mm exhaust valves,
    and custom valvesprings
    Camshaft: SoCal Diesel custom solid roller;
    specs classified
    Valvetrain: stock geardrive timing set
    and rocker arms;
    SoCal Diesel custom pushrods
    Induction: custom sheetmetal intake manifold
    with 16 runners and dual 3.5-inch plenums;
    custom ram air scoop and inlet piping
    Ignition: none
    Power adder: Twin Garrett T-38R
    turbochargers set at 30 psi,
    custom dual Bell intercoolers
    Fuel system: PPE dual fuel pumps, PPE lift pump
    Computer: stock, reprogrammed by PPE
    Exhaust: custom Bassani turbo headers,
    custom dual 3-inch exhaust
    with no mufflers
    Cooling: Ron Davis radiator,
    dual Spal electric fans,
    stock water pump
    Output: Estimated 950 hp and 1,800 lb-ft
    DRIVETRAIN
    Transmission: PPE-built Allison 1000
    five-speed auto,
    ATS 2,200-stall converter
    and billet flexplate
    Rear axle: Fast Eddie’s 9-inch rearend
    with 35-spline axles, 3.25:1 gears,
    and Detroit Locker differential
    CHASSIS
    Front suspension: Art Morrison front clip
    with C5 Corvette aluminum control arms,
    sway bar, and spindles; Koni coilovers
    Rear suspension: Art Morrison four-link,
    Koni coilovers
    Brakes: Wilwood 14-inch rotors
    and six-piston calipers, front;
    Wilwood 16-inch rotors
    and four-piston calipers, rear
    WHEELS & TIRES
    Wheels: DPE S-5 18x8, front; 20x16, rear
    Tires: Mickey Thompson
    26x12x18 Sportsman radials, front;
    33x22x20, rear
    w streszczeniu silnik diesla o mocy 950 KM i 1800 lb-ft czyli jakies 2500 Nm nieźle.
    źródło: Popular hot rodding
    mazi_gc's Avatar
    Nov 2008
    Warszawa
    Saab 9-5 2.3T Aero
    4 razy
    piekna maszina
    kto by pomyslal ze tam siedzi dieselek
    mistrzostwo
    OFFCA's Avatar
    Oct 2007
    NEIGHBOURHOOD
    Audi A3 1998rok
    1.9TDI AHF
    47 razy
    52 razy
    ogladam i ogladam i myśle fajna elegancko zrobiona maszyna
    Ale jak zobaczyłem tylnie opony to podziekowałem
    aaaaaa no i własnie ten moment hehehe tam wał itd to musi byc chyba z tytanu albo kryponitu (superman)
    numer obozowy 2483 : 22.10.2007
    22.10.2007-->10.02.2008 forumowicz,
    10.02.2008-->31.12.2011 klubowicz,
    01.01.2012---> kombatant wojenny, to juz rok na emeryturze
    tysiace postów, 27 tematów, dziesiątki spotów, 2 OP, 6 ostrzeżeń oto JA
    SONICS's Avatar
    Oct 2007
    MS-AGH
    AUDI "BlueBeast"
    1.9TDI AHF
    4 razy
    Jest piękne autko
    Ale te tylnie opony normalnie miazga
    Przemykająca niebieska bestia na ulicach Krakowa...
    sławko's Avatar
    Sep 2008
    Wesoło Wieś :D
    była ->Milka<- jest ZeBeRkA :D
    24 razy
    8 razy
    miiiiodzio cos pieknego diesel -> to jest to
    Kam1kaze's Avatar
    Mar 2008
    GDAŃSK
    1.8T AGU
    25 razy
    5 razy
    Piekny!
    szkoda że diesel
    malik's Avatar
    Sep 2007
    warszawa
    Mam dres :)
    38 razy
    45 razy
    O kurcze, poleglem. Moc i moment miazdzy. w tym przypadku wybor takich opon byl prawidlowym posunieciem. Chyba najmocniejszy diesel jakiego widzialem
    Maugo's Avatar
    Mar 2009
    kobieta
    Poznań
    Audi A6 Q S-Line
    14 razy
    7 razy
    Cytuj Oryginalnie napisane przez Kam1kaze Pokaż post
    Piekny!
    szkoda że diesel
    piękny ! fajnie że diesel
    Zabezpieczenia medyczne imprez masowych
    www.med-event.pl
    Zbanowany Zbanowany
    Sep 2008
    kobieta
    Warszawa
    BMW E60 LCI & Subaru Impreza STI
    10 razy
    16 razy
    cudeńko
    wallenrod's Avatar
    Nov 2008
    Szczecin
    obecnie bez autka, moje A3 niestety do kasacji :(
    Piękne to autko Jak będę stary i bogaty to sobie takie kupię
    ...bo auto bez czterech kółek na masce to g... nie samochód
