na naszym forum tez troche o tym bylo
http://a3-club.net/forum/showpost.ph...00&postcount=7
pozdro Michał.
czyli z tego co zrozumiałem w AUM siedzi te same turbo co w seryjnej 180km ?
a jak jest s innymi 1.8t ? tylko w AUM siedzi k03s ?
Odgrzewam kotleta, ale żeby dokończyć temat wkleję to co znalazłem na RF. Pozwolę sobie tu zamieścić, nie pamiętam kto jest autorem - miałem to zapisane na dysku. (na niebiesko dopisałem przykładowe kody silników w których są te turbiny)
"First of all, we don't produce any turbo that we call K03S. But I hope I can
answer your questions with the following explanations.
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator AGU
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator AUQ
K03-053 150 hp, 85 N actuator AUM
K03-058 150 hp/180 hp, 85 N actuator
Consequentially, putting a 180 hp turbo on a 150 hp engine will not bring
about any change in performance, but putting on a K03-052/053/058 instead of
the older versions will bring a slight improvement in engine efficiency.
Additionally, with re-mapping the ECU you can achieve about 215 hp without
danger of overspeeding the turbo. With the older turbos, 195 hp is the
limit.
With the K04 that's also commonly used (5304 950 0001) the power output
should not be more than 220 hp. That means, changing a K03-052/053/058
against a K04 does not make a lot of sense.
I hope that these details answer your questions. If you need more info, one
of our service distributors will be glad to help you. Their addresses are on
our website http://www.turbodriven.com.
Mit freundlichen Grüßen/Best regards,
BorgWarner Turbo Systems GMBH"
To też mam na dysku (znalazłem ana racinforum kiedyś), więc wklejam:
Uploaded with ImageShack.us
Ostatnio edytowany przez Dybek - 30-08-11 o 18:36
227KM337NM
