Pokazane rezultaty 1 do 2 z 2
Temat: Prośba o radę - Scan po raz pierwszy.
    Radom
    Domyślny Prośba o radę - Scan po raz pierwszy.
    Witam. Właśnie dzisiaj dostałem kabelek i na gorąco przeskanowałem samochód. Prosiłbym o radę czy mam mam się czym martwić na początek
    Oto mój pierwszy log ze skanowania błędów:
    Kod:
    VAG-COM Version: Release  311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01     -------------------------------------------------------
       Controller: 06A 906 018 AR
       Component: 1.8L R4/5VT MOTR HS D05
       Coding: 04000
       Shop #: WSC 06435
    1 Fault Found:
    00282 - Throttle Position Actuator (V60)
                27-10 - Implausible Signal - Intermittent
    Readiness: N/A
    Address 03     -------------------------------------------------------
       Controller: 1J0 907 379  E
       Component: ABS/EDS 20 IE CAN  0001
       Coding: 13504
       Shop #: WSC 06435
    1 Fault Found:
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    Address 08     -------------------------------------------------------
       Controller: 8L0 8 ö8 L08
       Component: 8L0820043D
       Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17     -------------------------------------------------------
       Controller: 8L0 919 880 E
       Component: AB-KOMBIINSTR. VDO D03
       Coding: 04042
       Shop #: WSC 19411
       IMMO-IDENTNR:
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
                30-10 - Open or Short to B+ - Intermittent
    Address 35     -------------------------------------------------------
       Controller: 8L0 862 257 G
       Component: ZV-Pumpe, DWA, Funk D05
       Coding: 13130
       Shop #: WSC 06435
    3 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
                35-00 - -
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    00956 - Key 2
                09-00 - Adaptation Limit Surpassed
    Address 45     -------------------------------------------------------
       Controller: 8L0 951 173
       Component: Innenraumueberw.    D04
       Coding: 00001
       Shop #: WSC 06435
    1 Fault Found:
    01382 - Alarm triggered by Anti-Theft Sensor: Front Left
                35-00 - -
    Address 56     -------------------------------------------------------
       Controller: 4B0 035 186
       Component:  Radio              D01
       Coding: 00000
       Shop #: WSC 00000
    No fault code found.
    End   -------------------------------------------------------
    Najbardziej martwi mnie błąd 1312 nie wiem co oznacza. Kolejny to błąd nr 282 Serwomotor pozycji przepustnicy – V60. Czy to coś poważnego ?
    Wiem też, że czujnik G2 chyba zepsuty lub ma zwarcie ?
    Pawel_yu's Avatar
    Feb 2009
    Pruszków
    SB
    2.0 TDI - CRLB( 150 KM)
    122 razy
    19 razy
    nie masz sie czym matrwic
    pierw skasuj bledy i zobacz czy nie powroca
  3. Podziękowania dla Pawel_yu za pomoc w problemie
    xury (09-12-10)
