Polar-FIS do 8P
W końcu po latach producent wypuścił wersje dla 8p,
działa tak z czerwonymi jak i białymi zegarami
Wielu na pewno zna to urządzenie z Leona FR/Cupra czy Golfa GTI/R i wie jakie ma możliwości
W przypadku 8p trzeba miec kierownice multif, przy innych modelach ( skoda, seat, golf ) nie jest wymagana
https://www.youtube.com/watch?v=8KlAUdqC-QU
https://www.youtube.com/watch?v=2vjQC22dV5U
i parę pokazujących mozliwości tego np w leonie :
https://www.youtube.com/watch?v=6ywON_VVXYI
czy mk6 :
https://www.youtube.com/watch?v=H7SBIQSdptY
https://www.youtube.com/watch?v=HeKgshFcE2g
nie wiem czy jest już, działa, ile kosztuje vfiz na 8p, polar fis tani nie jest, ale mozliwosci, aktualizacje itd
cena ok 250E
( polar fis advanced )
Polar FIS+ Advanced, What is it ? Advanced Polar FIS is the evolution of FIS + unit. It adds new parameters in addition to new features.
Polar FIS + enabled viewing vehicle parameters in the FIS screen, but Polar FIS Advanced, as well as incorporating more parameters, includes new features like the ability to modify the number of flashes of intermittent comfort indicators, function automatic lowering of the mirror on the passenger side when engaging reverse and some functions which are can only be activated with Diagnostic cable such as VCDS.
What parameters can be displayed with Polar FIS+ Advanced ?
- Real speed (readed from ECU)
- Oil temperature (°C / °F)
- Coolant temperature (°C / °F)
- Outdoor temperature (°C / °F)
- Admision temperature (°C / °F)
- Turbo pressure
- RPM motor
- Voltage of the battery.
- Fuel remaining (Litres / Gallons)
- Atmospheric pressure
- Pressure fuel pump
- Motor load.
- Ambient Temperature (engine ECU)
- Coolant temperature engine output.
- Coolant temperature leaving the radiator.
- Mass air flow
- Admision pressure
- Sensor 1 throttle pedal
- Sensor 2 throttle pedal
- Sensor 1 throttle valve
- Sensor 2 throttle valve
- Horse power used (CV)
- Oil level
- Minimum oil level
- Brake master cylinder pressure
- Pressure in the fuel rail
- Torque used NM
- Injection timming
- Injection quantity
- Injection angle
- Injection start
- TV Free function
VERY IMPORTANT INFORMATION
Not all parameters are supported in all engine ECU, to know that data can be displayed, see the list of supported ECU: http://www.auto-polar.com/downloads/Supported_ECUs.xls
What is the role of intermittent comfort ?
The role of intermittent comfort, allows you to select the number of intermittent flashes that the comfort indicator makes. Standard, with one touch gives 3 flashes intermittently with Polar FIS Advanced, select up to 10 flashes.
You can also cancel additional flashes by pressing the indicator comfort again, for example, if you have set the indicator at 10 flashes on comfort, it will flash with a short press on the control 10 flashes, unless pressed again to cancel.
What is the function of mirrors down ?
Advanced Polar FIS can be configured to engage on selection of the reverse gear for the passenger mirror to dip down automatically to a preset position. There are 2 modes: Manual and Automatic.
In manual the mirror will lower only if the passenger position âLâ is selected.
In automatic, the mirror will be lowered only when the car is parked with the indicator directed towards the space.
NOTE: Due to construction features of vehicles it cannot be guaranteed that mirror position will be "perfect". On models equipped with this function from factory the mirror incorporate a position sensor, which does not happen with those without park assist mirrors, so the mirror will function in the same way, but can not be guaranteed to position "millimeter perfect".
What diagnostic functions are available ?
- Modification of the sensitivity of the rain sensor.
- Modification of the sensitivity of the light sensor.
- Enable / Disable American DLR.
- Enabling / Disabling daytime running lights.
- Enabling / Disabling cornering fog lights.
- Enabling / Disabling second rear fog light (where bulb exists).
- Enable / disable automatic closing from 15 km / h.
- Enable / disable rain closing.
- Enabling / Disabling one touch closing windows.
- Enable / Disable hazard warning in case of sharp braking.
NOTE: These functions, Polar Advanced FIS performs are via coding of the ECU with the requested function, so if this function is not supported by your vehicle ECU, then it cannot be activated.
What are the other features of the Polar FIS+ Advanced ?
- Built in VIM to enable video on stereo screen while vehicle is in motion.
- POLAR Advanced FIS supports OEM bluetooth and Fiscon bluetooth, unlike other products, POLAR Advanced FIS does not use the Bluetooth menu in the FIS, but creates a new menu called Advanced POLAR FIS.
- The name of the created menu is customisable, which can substitute the name POLAR Advanced FIS by the text you want (up to 10 characters)
- Option to turn off the POLAR Advanced FIS screen off making the unit undetectable when taking the car in for service or repair. Is reactivated by simply pressing the OK button on the steering wheel or windshield wiper lever for 10 seconds.
- Automatic temperature units (° C, ° F), Speed (kmh / mph) and Size (Litres / Gallons) selected in the FIS.
- Manual selection of the units in which you want to display the parameters relating to pressure. Automatic, mbar, bar, PSI.
- Multi-function steering wheel / Wiper stalk control.
The keys can be set from within the FIS POLAR Advanced menu do the following.
Modify volume.
Changing audio track.
Change the parameters displayed in the bottom of the screen line POLAR FIS +.
You can also configure the keys inside the AUDIO menu do the following.
Modify volume.
Change audio track (useful for cars in which the multifunction steering wheel is not installed at the factory and these keys do not work).
IMPORTANT: FOR CARS THAT ARE NOT EQUIPPED MULTIFUNCTION STEERING WHEEL, THE OPTION OF CHANGING AUDIO TRACK IS NOT AVAILABLE.
KEY FEATURES OF THE WHEEL IS NOT AVAILABLE IN ALL THE VEHICLES, since it depends on the vehicle configuration.
- Polar Advanced FIS automatically installs itself in the gateway, so you do not need diagnostic software after installation
- Updates via the Internet, via our website: http://www.auto-polar.com/index-load-support.htm
- New aluminum frame.
PolarFIS Audi Firmware Ready !!
We are proud of present a new firmware for PolarFIS that supports AUDI vehicles.
The models supported for this new firmware are this :
Audi A3 8P (Red/White FIS)
Audi S3 8P (Red/White FIS)
Audi S3 Sportback 8P (Red/White FIS)
Audi RS3 8P (Red/White FIS)
From now, actual PolarFIS in market and future PolarFIS will support AUDI, so if you are interested in use it for one AUDI vehicle, you simply must access to the support area, and choose the new firmware created for this brand.
Actual features and functions, now are available for AUDI vehicles.
[+] More than 140 parameters available for monitorize
[+] 18 Diagnosis functions ready to use
[+] Choose between 15 languages
IMPORTANT : For use the PolarFIS device with your AUDI vehicle you need have installed multifunction steeringwheel. In other brands like SEAT, SKODA or VW is not needed but AUDI vehciles must have it.
It sounds like another group buy ;)
Jestem zainteresowany ale powiedzcie mi panowie wskaźniki Temp w dolocie, EGT oraz Boost są miarodajne? Tak samo jak osobne zegary?
słabo to wyglada na jednej linijce. Ja na zime zakupie blitz r-vit dc pod rnse.
https://www.youtube.com/watch?v=wBrgbLU0FKU
bardziej osobiście mi się podoba produkt P3Cars (Interfejs z wyświetlaczem w kratce nawiewu) łączy się go wtykiem do gniazda ODB
Gadżet fajny ale cena też zaporowa:
https://www.vividracing.com/catalog/...150715599.html
Hmm, 273EUR za wersję do 8P która używa (i zabiera) tylko 2 linijki wyświetlacza RDS radia, oraz Menu w 2 linijkach, czy to nie lipa ??
Bo reszta filmików pokazuje że wygląda OK tylko w VW a nie w 8P...
VFIZ bardziej rozbudowany jest od Polara,ale chyba nie ma jeszcze wersji do 8P. Testy robili i ucichło.
Kurde ale odgrzałem kotleta
Tak zdecydowanie VFIZ wydaje się lepszy, a sam czekam na wersję do 8P przedlifta
Ciekawe czy wogóle się doczekamy.
Wersja do 8P sie caly czas testuje. :)
