http://vaglogi.pl/log-011_13I7Kpl.html ktoś doradzi czemu tak późno turbo wstaje wężyki podciśnienia ok błedów nie wywala
logi statyczneCytuj:
Konkretnie to zacznij od podpięcia interfejsu i diagnostyki, bez tego to błądzenie po omacku.
Jutro jeszcze podrzuce dynamiczne.Kod:VCDS-Lite Version: Release 1.2
Friday, 26 April 2019, 16:38:45:0
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: 038-906-018-AGR.LBL
Controller: 038 906 018 BP
Component: 1,9l R4 EDC 0000SG 2110
Coding: 00002
Shop #: WSC 06313
VCID: 65BD3297EC79
3 Faults Found:
17958 - Charge Pressure: Control Deviation
P1550 - 35-10 - - - Intermittent
17563 - Shareware Version. To Decode all DTCs
P1155 - 35-10 - Please Register/Activate - Intermittent
16485 - Shareware Version. To Decode all DTCs
P0101 - 35-00 - Please Register/Activate
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
VCID: 361FA5DB015F
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03143
Shop #: WSC 06313
VCID: 29257EA7C0E1
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
Address 15: Airbags Labels: 8L0-959-655-AI7.LBL
Controller: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 41F5C6075891
Address 17: Instruments Labels: 8L0-919-xxx-17.LBL
Controller: 8L0 919 860 D
Component: AB-KOMBIINSTR. VDO D09
Coding: 00140
Shop #: WSC 00000
VCID: 3905AEE73041
IMMO-IDENTNR: AUZ7Z0W0640395
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00000
Shop #: WSC 06313
VCID: 3E0FBDFB296F
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
End --------------------------------------------------------------------------------------------------
Ja mam inny problem z 1.9TDI. Przed wymianą EGR który wypluwał olej silnik dostawał przeładowania turbo, teraz na nowym egr ma niedoładowanie turbiny do 80 km/h jedzie max. Zauważyłem że na wyłączonym silniku kiedy ruszam klapą gaszącą to z zaworka n239 wychodzi powietrze. Czy to może być problem ?
Pacjent: Audi 1.9 tdi 110 asv
Problem polega na notlauf przy 110-130
Problem pojawił się około pół roku temu i ustąpił po podmianie zaworka n75 z a4 ajm. Około tydzień temu problem powrócił.
Po zgaszeniu i dopaleniu powraca do normy gdy znowu nie depne do około 110-130
Jedyny błąd jaki pokazuje to 17965
Dotychczas wykonane kroki.
-podmieniłem 3 różne zaworki n75 (łącznie z tym od egr)
-Ruszałem sztangą gruszki. Ręka jest to niemożliwe (chowa się w całej płaszczyźnie)
-wężyki były wymienione pół roku temu, więc nie stawiam na nie, ale możecie podsunąć pomysł jak je sprawdzić żeby znów nie zmieniać
-Jeden zaworek poświęcony na eksperymenty z czyszczeniem (dalej to samo)
Poniżej logi:
http://vaglogi.pl/log-011_003_007_53fYuU.html górne kolumny - brakło miejsca do rozpędzenia się. Dolne kolumny - przeszedł w tryb i od razu odpuściłem
http://vaglogi.pl/log-011_eNsCoV.html
Odkręć gruszke od mocowania chyba dwie śruby 10 , wtedy można poruszać sztangą z całym zakresie
Jak ją odkrecisz to wtedy sprawdzisz czy sztanga się nie zacina, ruch góra dół położenia krańcówe. metaliczne płukanie będzie sygnałem że jest ok, natomiast chrapanie to katar
Dziś zdemontowałem gruszkę i jest w niej mnóstwo rdzy i chodzi dość ciężko. Dźwignia przy turbinie stawia dość duży opór w połowie i słychać taki przeskok.
Co radzisz zrobić?
Mam jeszcze pytanie. Żeby wyjąc turbinę do czyszczenia potrzeba spuszczać olej?
Audi a3 8l 1.9 110km ASV
Geometria chodzi w całym zakresie
Zaworek N75 podmieniany
Nie przechodzi w tryb awaryjny
Niedoładowanie na wyższych obrotach
http://vaglogi.pl/log-011_003_R9C2do.html
