Cytuj:
Friday,22,August,2014,16:11:21:10074
VCDS Version: Beta 11.6.0
Data version: 20111008
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A057189 Mileage: 311460km/193532miles
Address 01: Engine Labels: 06A-906-033-AVU.lbl
Part No: 06A 906 033 J
Component: SIMOS33 1,6l 2V 00HS3488
Coding: 00211
Shop #: WSC 06435
VCID: 2647F2ABEA27
WAUZZZ8LZ1A057189 AUZ5Z0YD184010
2 Faults Found:
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
18068 - Coolant Fan Control 1: Short to Ground
P1660 - 35-00 - -
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 06435 000 00000
VCID: 2A5F069BFE3F
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0101
Coding: 01040
Shop #: WSC 06435
VCID: 2D550D87CFD1
4 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 00004
Shop #: WSC 06435
VCID: 458555277761
No fault code found.
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 900 H
Component: KOMBI+WEGFAHRS. M73 D52
Coding: 08142
Shop #: WSC 00000
VCID: 306B14F3D8E3
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 C
Component: ZV-Pumpe D14
Coding: 02049
Shop #: WSC 06435
VCID: 2D550D87CFD1
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
01365 - Lock/Unlock Switch; Interior
01389 - Tailgate Open Switch (F124)
00991 - Interior Lights
28-00 - Short to Plus
End ---------------------------------------------------------------------
drugi log po jakimś niedłuższym czasie
Cytuj:
Friday,22,August,2014,17:04:42:10074
Coding: 00211
Shop #: WSC 06435
VCID: 2647F2ABEA27
2 Faults Found:
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 35-00 - -
P1660 - 35-10 - - - Intermittent
Readiness: 1010 1101
Coding: 0001025
VCID: 2A5F069BFE3F
Coding: 01040
Shop #: WSC 06435
VCID: 2D550D87CFD1
2 Faults Found:
Coding: 00004
Shop #: WSC 06435
VCID: 458555277761
Coding: 08142
Shop #: WSC 00000
VCID: 306B14F3D8E3
Coding: 02049
Shop #: WSC 06435
VCID: 2D550D87CFD1
