Takie błędy mam u siebie:
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 001 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 126043 km
Time Indication: 0
Date: 2014.11.29
Time: 20:02:16
Freeze Frame:
RPM: 2228 /min
Load: 25.5 %
Speed: 91.0 km/h
Temperature: 79.0°C
Temperature: 1.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.605 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 16
Reset counter: 255
Mileage: 126311 km
Time Indication: 0
Date: 2014.12.01
Time: 17:05:07
Freeze Frame:
RPM: 842 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 19.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 127382 km
Time Indication: 0
Date: 2014.12.17
Time: 17:56:52
Freeze Frame:
RPM: 1925 /min
Load: 11.0 %
Speed: 66.0 km/h
Temperature: 75.0°C
Temperature: 12.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.478 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 127382 km
Time Indication: 0
Date: 2014.12.17
Time: 18:01:09
Freeze Frame:
RPM: 776 /min
Load: 25.5 %
Speed: 2.0 km/h
Temperature: 79.0°C
Temperature: 16.0°C
Voltage: 14.224 V
000311 - Oxygen (Lambda) Sensor B1 S2
P0137 - 002 - Signal too Low - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 127426 km
Time Indication: 0
Date: 2014.12.18
Time: 19:20:09
Freeze Frame:
RPM: 2283 /min
Load: 36.8 %
Speed: 93.0 km/h
Temperature: 81.0°C
Temperature: 20.0°C
Voltage: 14.351 V
Readiness: 0000 0001
Druga sonda do wymiany? Czy jak to rozumieć? Mogę ją wypuścić na podkładce żeby mniej zbierała i będzie spokój? Na przeglądzie to mi akurat nie zależy :P
