Prośba o analizę logów
mógłby ktoś mi napisać co to za błąd od poduszki / silnika?
i czy cała reszta jest ok?
Kod:
Tuesday,17,January,2017,16:50:28:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: License Plate:
Mileage: 173450km-107776mi Repair Order:
Chassis Type: 8L - Audi A3/S3 (1997 > 2003)
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 173450km/107776miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 AF
Component: 1.8L R4 5VT 0004
Coding: 05600
Shop #: WSC 06313
VCID: 62CB4C03EEBA6A0EE27-5072
1 Fault Found:
17696 - Boost Pressure Control Valve (N249)
P1288 - 35-00 - Short to Plus
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 L
Component: ABS/EDS 20 IE CAN V004
Coding: 13504
Shop #: WSC 06435
VCID: 3A7BD46326AA42CE9A7-4A9C
1 Fault Found:
01279 - Longitudinal Acceleration Sensor (G251)
27-00 - Implausible Signal
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOA3 KLIMAVOLL
VCID: 29591B2FD30CF956E3D-2566
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 4189A38F4B7C1116DBD-5072
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 880 K
Component: AB-KOMBIINSTR. VDO D15
Coding: 04142
Shop #: WSC 00000
VCID: 428BAC834E7A0A0EC27-50E6
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0X0870280
IMMO-IDENTNR: AUZ7Z0X0870280
No fault code found.
Address 22: AWD Labels: None
Part No: 02D 525 554
Component: HALDEX LSC ECC 000900
Coding: 00000
Shop #: WSC 00000
VCID: E0CFC60B60B6F81E743-49D8
No Faults Found
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 K
Component: ZV-Pumpe, Funk D11
Coding: 12864
Shop #: WSC 06313
VCID: 3D71DF7F378475F6BF5-4DD6
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A8 RDW D18
Coding: 01108
Shop #: WSC 00000
VCID: E6C3D0138292962E8EF-50E6
End ---------------------------------------------------------------------
Ostatnio zaczela mi sie pojawiac kontrolka silnika, dzisiaj pojechalem do znajomego podpiac pod komputer i wyrzucilo te dwa bledy pokazane na zdjeciach.
Czy sa to rzeczy ktore trzeba natychmiast robic oraz z jakimi orientacyjnie kosztami mam sie liczyc ?
Dodam ze jutro jade w "trase" ok 250km i czy bez problemu mozna pojechac i sie tym nie przejmowac?
Z gory dziekuje za wszystkie odpowiedzi!
http://i66.tinypic.com/2ng4pbm.jpg
http://i67.tinypic.com/j99ai0.jpg
Error czujnik NOx 2.0Fsi
Od paru dni swieci mi sie chek eigen .Silnik 2.0 fsi 215 000km.Po skanowaniu wychodzi blad P2203-wysokie napiecie w obwodzie czujnika NOx(rzad 1,czujnik 1)
Silnik pracuje bez zmian.Silnik nie trzesie ,moc jak wczesniej,spalanie w normie. Po wykasowaniu bledu pojawia sie spowrotem po okolo 5 dniach.Gdzie ten czujnik sie znajduje ??Czy to ten za katem ,czy przed ?
Odświeżyć i podłączyć się mi wypada
Oto błędy
Centralny zamek KW71 (35h)
Identyfikacja 8L0863257L (Audi A4 (8D) 1995-2001 Centralny zamek)
Kody błędów:
1/5 1367 -Wyłączenie pompy zamka centralnego
2/5 1366 - Otwarcie po sygnale zderzenia
3/5 1361 - Włącznik układu przeciwkradzieżowego DWA - zamknąć
4/5 1389 - Włącznik otwarcia klapy bagażnika - F124
5/5 991 - Oświetlenie wnętrza
viperaberus
01367 masz problem z centralnym a dokładnie z pompką centralnego/odpowiedni temat tu
http://www.a3-club.net/forum/showthr...23#post1375823
przekroczony czas pracy pompy zamka centralnego (możliwa nieszczelność) a do tego masz błąd 01366 co w połączeniu oznacza że najprawdopodobniej auto było uderzone(jak sensor poduszki wykryje zderzenie wysyła sygnał do centralnego żeby otworzyć zamek aby osoby będące wewnątrz mogły w miarę możliwości wyjść z auta lub zostać z niego wyciągnięte)
01361 https://translate.google.pl/translat...ml&prev=search
01389 Włącznik otwarcia klapy bagażnika/wyczyść mechanizm i sprawdź stycznik-kable
brak oświetlenia w bagażniku po otwarciu to najczęstszy objaw
00991 masz problem z oświetleniem wewnętrznym/sprawdź bezpieczniki oraz żarówki-rozpiska tu
http://www.a3-club.net/forum/showthr...23#post1147623
klamamoto blad był w kategorii "Instruments" jesli o to chodzi i pojawil sie juz w 2010 z tego co widze byc moze ktorys modul do wymiany tylko ktory ? Albo cos z kodowaniem
