Cytuj:
Friday,23,November,2012,12:52:44:13314
VCDS Version: Release 908.0
Data version: 20090911
Mileage: 232180km/144269miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 BA
Component: 1,9l R4 EDC 01SG 1812
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 E
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
1 Fault Found:
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03143
Shop #: WSC 06435
3 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: Redir Fail!
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06435
No fault code found.
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 860 D
Component: AB-KOMBIINSTR.UN4 D05
Coding: 00040
Shop #: WSC 07777
Part No: IMMO
Component: IDENTNR: AUZ8Z0W0280017
IMMO-IDENTNR: AUZ8Z0W0280017
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
00771 - Fuel Level Sensor (G)
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D06
Coding: 13130
Shop #: WSC 04096
3 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
End ---------------------------------------------------------------------
