Cytuj:
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 14428012092600FC281401ED901D00413800
Shop #: WSC 06314 000 00000
VCID: 75E5E5E760E5
3 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 74691 km
Time Indication: 0
Date: 2012.10.01
Time: 07:50:54
Freeze Frame:
Count: 2
Count: 2
Count: 12800
Count: 294
Count: 42496
Count: 0
Count: 0
Count: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 74699 km
Time Indication: 0
Date: 2012.10.01
Time: 08:05:25
Freeze Frame:
Count: 2
Count: 32768
Count: 12800
Count: 8193
Count: 49722
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 5
Reset counter: 11
Mileage: 74666 km
Time Indication: 0
Date: 2012.09.30
Time: 06:26:27
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 45312
Count: 57856
Count: 0
Count: 0
oraz
Cytuj:
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5F069BF9DB
3 Faults Found:
16353 - Control Module - Internal Malfunction
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 74323 km
Time Indication: 0
Date: 2012.06.09
Time: 01:39:15
Freeze Frame:
Battery Volts: 11.7 V
DU
Temperature: 27.0∞C
Error Code: 14745
Torque: -6.8 Nm
Torque: -2.304 Nm
RPM: -2388 /min
00573 - Steering Torque Sensor (G269)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 3
Reset counter: 10
Mileage: 74700 km
Time Indication: 0
Date: 2012.10.01
Time: 08:08:01
Freeze Frame:
Battery Volts: 12.2 V
DU
Temperature: 34.0∞C
(no units): 65
(no units): 32
Torque: 0.0 Nm
Count: 837
02391 - Terminal 30 Reference
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 12.88 V
PD
Temperature: 34.0∞C
Speed: 50.0 km/h
Torque: 0.0 Nm
Torque: 0.000 Nm
Term 15 On
