Oryginalnie napisane przez
matigdy
przeswietlilem kolezance jej A3 VAGiem i dostalem taki zapis:
Address 01 -------------------------------------------------------
Controller: 06A 906 018 C
Component: 1,8l R4/5V MOTR HS V04
Coding: 04000
Shop #: WSC 00000
5 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
00670 - Throttle Position Sensor (G127)
06-10 - Signal to High - Intermittent
01165 - Throttle Body Control Module (J33
17-10 - Control Difference - Intermittent
16507 - Throttle Position Sensor (G69): Signal too High
P0123 - 35-10 - - - Intermittent
17913 - Throttle Idle Switch (F60): Does not Close or Open Circuit
P1505 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A3 KLIMAVOLLAUTOMAT_D72
Coding: 03140
Shop #: WSC 06313
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 880 AX
Component: AB-KOMBIINSTR. VDO D17
Coding: 04142
Shop #: WSC 22179
IMMO-IDENTNR: AUZ7Z0V0122866
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
End -------------------------------------------------------
Prosze kogos o analize
matigdy is online now Zgłoś post Cytuj zaznaczony text
