W ABS ZERO KODÓW ZADNYCH BŁĘDÓW NA ZEGARACH ABS ESP I KONTROLKA HAMULCA NA FISIE I ZEGARACH ADAPTACJE POROBIONE WSZYSTKO NIBY OK A NA LICZNIKU CHOINKA
Wednesday,16,November,2016,18:02:48:15387
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8P14A139103 License Plate:
Mileage: 185090km-115009mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P14A139103 Mileage: 185090km-115009miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC G000SG 9884
Revision: 12345678 Serial number: AUX7Z0D1FN408A
Coding: 0000072
Shop #: WSC 80093 222 69422
VCID: 275C792596D10F7ADD-8072
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7AB05175638292B2-806E
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 034087 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
VCID: 2D508B0DB42D252A27-8078
Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl
Part No SW: 8P0 907 279 HW: 8P0 907 279 *
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000526557
Coding: 00884F00A2141000000000000000000000
VCID: 7AFA705135E34292F2-802E
Subsystem 1 - Part No: 8P2 955 119 A Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
VCID: 4384CDB502A9C35AE1-8016
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
VCID: 4188C7BD18B5D14AF3-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 H HW: 8P0 920 982 H
Component: KOMBIINSTR. VDO H01 0080
Revision: D0H01002 Serial number: 2244J002000449
Coding: 0004802
Shop #: WSC 80093 222 71269
VCID: 3E72BC41694BAEB28E-806A
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010411900E5
Coding: 3D0F0B42070101
Shop #: WSC 06435 123 12345
VCID: 285E7A199BCF0002D4-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01002 Serial number: AUX7Z0D1FN408A
Shop #: WSC 15305 000 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3978AF5D7065898ABB-806C
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.9 1202
VCID: 2E528C01B92B5E321E-807A
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 00383 383 80878
VCID: 79F86F5D30E5498AFB-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001088402
VCID: 70EE5279639F08C24C-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 152 HW: 8P0 035 152
Component: chorus II H53 0060
Revision: 07S Serial number: AUZ2Z2D1213150
Coding: 0001204
VCID: 68DE3A195B4FC00214-803C
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5686098F372C2230-8078
End-------------------------(Elapsed Time: 01:30)--------------------------
