The Diesel Fuel Cooler Guide
Pytanie do mocnych dieseli zarowno na forum jak i w ogole w PL:
dlaczego nie stosujecie czegos takiego jak w ponizszym linku:
http://www.seatcupra.net/knowledge_b...ler_guide.html
Cytuj:
There are 3 major reasons to install a fuel cooler on your tuned PD TD:
Reduced intake diesel temperatures will reduce temperatures inside the motor and consequently EGT temperatures.
There’s a fuel limiting table in the code that limits the injected diesel quantity, depending on the fuel temperature. To keep injection quantity at its maximum you need to keep the fuel under 80ºC. This may sound simple, but under spirited driving or track day situations you’ll easily get fuel temperatures in excess of the 80ºC. During the summer months, I easily see in excess of 90ºC.
Diesel at higher temperatures has less lubrification properties, when compared with cooler diesel.
After testing (unfortunately not during the hot summer months), we were able to get less hesitation during hard acceleration and a +2hp gain on the dyno.
Re: The Diesel Fuel Cooler Guide
Cytuj:
Oryginalnie napisane przez Mach
ludzie z czołowki SSS stosuja, jak rowniez chodniczke oleju
