Prośba o radę - Scan po raz pierwszy.
Witam. Właśnie dzisiaj dostałem kabelek i na gorąco przeskanowałem samochód. Prosiłbym o radę czy mam mam się czym martwić na początek :)
Oto mój pierwszy log ze skanowania błędów:
Kod:
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 AR
Component: 1.8L R4/5VT MOTR HS D05
Coding: 04000
Shop #: WSC 06435
1 Fault Found:
00282 - Throttle Position Actuator (V60)
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 E
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 06435
1 Fault Found:
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 08 -------------------------------------------------------
Controller: 8L0 8 ö8 L08
Component: 8L0820043D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 880 E
Component: AB-KOMBIINSTR. VDO D03
Coding: 04042
Shop #: WSC 19411
IMMO-IDENTNR:
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D05
Coding: 13130
Shop #: WSC 06435
3 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
Shop #: WSC 06435
1 Fault Found:
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio D01
Coding: 00000
Shop #: WSC 00000
No fault code found.
End -------------------------------------------------------
Najbardziej martwi mnie błąd 1312 nie wiem co oznacza. Kolejny to błąd nr 282 Serwomotor pozycji przepustnicy – V60. Czy to coś poważnego ?
Wiem też, że czujnik G2 chyba zepsuty lub ma zwarcie ?
