Co jakiś czas załącza się EPC w moim Audi 3 v8. Po podłączeniu do komputera mam błąd P02990.
Przebieg 40 tys km
Gdzie szukać problemu ? Co może być przyczyna
Dziękuje za rady
Przebieg 40 tys km
Dziękuje za rady
a nie czasem bez 0 na koncu ? a bardzij zrozumialy numer bledu z VCDS to
16683/P0299/000665
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Contents
Possible Symptoms
- Reduced Power Output
- Limp Mode
Possible Causes
- Hoses/Pipes incorrect connected, disconnected or leaking
- Charger Pressure Control defective
- Turbocharger faulty
- Diverter Valve faulty
Possible Solutions
- Check Hoses/Pipes to/between Components
- Check / Clean / Replace Charge Pressure Control
- Check Turbocharger
- Check Diverter Valve
Special Notes
- If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
Gasoline
- When found in Hidden Content :
- Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
- RoW vehicles see: TPI 2016331 for details.
- NAR vehicles see: TSB 01-07-70 or 2013392 for details.
- When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: Hidden Content , Hidden Content , Hidden Content , Hidden Content and/or Hidden Content .
Nie pomagam na PW, nie muszę
