Od niedawna jestem posiadaczem Audi A3 8V sprowadzonego z USA. Mam problem z climatronikiem. Parują szyby, a VCDS wyrzuca następujące błędy.
Kod:
Saturday,04,December,2021,14:46:37:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
Hidden Content Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F BB BC
VIN: WAUEFGFF7F1119026   Mileage: 105386km-65483miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1D00124426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C57629547DAA42245-8078
1 Fault Found:
21425 - Secondary Air Injection System: Bank 1
          P0491 00 [101] - Insufficient Flow
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 105382 km
                    Date: 2021.12.04
                    Time: 13:01:19
                    Engine speed: 1127.50 /min
                    Normed load value: 20.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 8 °C
                    Intake air temperature: 5 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 13.710 V
                    Unlearning counter according OBD: 40
                    Engine: operating status: IS
                    Charge air pressure control valve position: actual value: 4.80 %
                    T_AST_SAE: 9 s
                    STATE_BPA[0]: OPM
                    Lambda probes actual: bank1: 1.2002
                    VLS_DOWN_SAE[1]: 1.275 V
                    TEMP_CAT_UP_1_SAE: 540.3 °C
Readiness: 1010 1101
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4515
   Revision: 05853104    Serial number: TFK01501281244
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1E33B85D016646B2DB-804A
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60565000001010
   Coding: 13FF6A9234210A750177030281C929C8562C5080C08194B4024100588208
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 489F3E05F362680241-801C
Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: 0360410900
   Coding: 030C0C
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3A7B54CDBD8E0A92C7-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 D    HW: 8V0 820 043 D
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000574120
   Coding: 03000014010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
   ROD: EV_AirCondiFrontVaAU37X.rod
   VCID: 336579E99AE4FBDA04-8066
   Relative humidity sensor in fresh air intake duct:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: 43284397000000000001
3 Faults Found:
328965 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 105382 km
                    Date: 2021.12.04
                    Time: 13:02:39
                    Voltage terminal 30: 14.4 V
                    Interior temperature: 4.6 °C
                    Outside air temperature: 2 °C
                    Front air distribution flap: actual value: 100.0 %
                    Front air distribution flap: actual value: 110
                    Front air distribution flap: specified value: 109
329477 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 105382 km
                    Date: 2021.12.04
                    Time: 13:02:39
                    Specified value for fresh air/recirc air flow flap: 868
                    Actual value for fresh air/recirculation air flow flap: 100.0 %
                    Actual value for fresh air/recirculation air flow flap: 868
329989 - Motor for Defroster Flap
          B1090 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 105382 km
                    Date: 2021.12.04
                    Time: 13:02:39
                    Defroster flap: specified value: 941
                    Defroster flap: actual value: 100.0 %
                    Defroster flap: actual value: 942
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011503800111
   Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79F98BC1F808C18A8E-802C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150216  042 0585
   Serial number:         150218150952
   Coding: 0A47F7
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 23721389
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Component: E1 - LDS MQB  H05 0032
   Serial number: 05 12 2014  00000790
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000061739857
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0005G3J700000
   Coding: 101F00
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 J    HW: 5Q0 959 655 J
   Component: AirbagVW20    009 0825
   Serial number: 003GCR01GCDE
   Coding: 9DCCFCC0000000005000001AC24800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 479D3D39FE7C677A48-8012
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H36 0350
   Serial number: 34178311B24021540745
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H36 0350
   Serial number: 34178312B24021540946
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Component: BF-Gewichtss.  H10 0046
   Serial number: 6940000Y150001AT4M0$
   Coding: 303139
   Side Sensor Driver Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 001 702 15
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F4D50531I
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 5 - Part No SW: -----------    HW: 480 001 702 15
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000009C0205315
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 202 15
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002C7198E152117-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 202 15
   Component: SideSensor_Pr  001 6149
   Serial number: 3520002B5198E154A172
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 801 15
   Component: FrontSensor_D  001 6149
   Serial number: 3550002BB1901DA1A2EC
   Coding: 2D2D2D
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 801 15
   Component: FrontSensor_P  001 6149
   Serial number: 3560002C71901DA64182
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 22021504400069
   Coding: A018
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0A1BC40DADEEDA1297-805E
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
   Component: KOMBI         H02 4292
   Coding: 0BED18192B8000080700FE001800000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 3E7358DDA1A626B2FB-806A
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2203
   Revision: --------    Serial number: 20021510802836
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011020
   ROD: EV_GatewConti_011.rod
   VCID: 72EBBCEDA57EB2D2CF-8026
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Component: E221 - MFL  H02 0014
   Serial number: 10 02 2015  D0028625
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00007.01.15
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 4683303DF9767E72B3-8012
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 15000028975002
   Coding: 5D00000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 34677AF59FEAFCE21D-8060
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Component: TSG FS        020 0028
   Serial number: 100215BB911128
   Coding: 00511F204000048000000002
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 428B2C2DD55E42529F-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 43852929CA444B5A94-8016
Address 47: Sound System (J525)       Labels: None
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN9012D4M
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 387F4EC58382188231-806C
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0028
   Serial number: 070215BB612835
   Coding: 005117204400048000000002
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 41892321D058594A86-8014
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 012A000101000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E187F1D410A5EAEA-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302B0FB009912
   Coding: 017301020000000021110002041A00102F000125010001047E
   ASAM Dataset: EV_MUHig6C3HBAS 001040
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Data medium:
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Serial number: --------------------
   Display unit 1 for multimedia system:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY202GAA
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000009011500020129
   Compact Disc Database:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 3006
1 Fault Found:
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 105382 km
                    Date: 2021.12.04
                    Time: 13:02:43
                    Voltage terminal 30: 14.6 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: No_signal
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 280115BAS02083
   Coding: 004117204000048000000002
   ASAM Dataset: EV_DCURearDriveMINKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      020 0028
   Serial number: 280115BAS02086
   ASAM Dataset: EV_DCURearPasseMINKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:38)--------------------------
