Witam dzis podlaczylem moja a3 pod vag w trybie auto scan i oto rezultat, Niestety nieznalazlem tlumaczen tych ostatnich bledow wie ktos moze co one oznaczaja???
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 AH
Component: 1,9l R4 EDC 00SG 1604
Coding: 00002
Shop #: WSC 06313
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A3 KLIMAVOLLAUTOMAT_D73
Coding: 03143
Shop #: WSC 06313
1 Fault Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-10 - Open or Short to B+ - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 860
Component: AB-KOMBIINSTR. VDO D11
Coding: 00040
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0V0107819
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
24 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
01389 - Tailgate Open Switch (F124)
22307 - Unknown Error Code
Unknown - 70-10 - Cylinder 3 - Intermittent
23331 - Unknown Error Code
Unknown - 02-00 - Signal Shorted to Ground
23587 - Unknown Error Code
Unknown - 103-10 - Unknown Error Elaboration - Intermittent
24099 - Unknown Error Code
Unknown - 39-00 - Output won't Switch or Short to Ground
23075 - Unknown Error Code
Unknown - 01-00 - Signal Shorted to B+
22819 - Unknown Error Code
Unknown - 01-10 - Signal Shorted to B+ - Intermittent
22563 - Unknown Error Code
Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent
End -------------------------------------------------------
