VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 C
Component: 1,8l R4/5V MOTR HS V06
Coding: 04000
Shop #: WSC 06325
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 E
Component: ABS/EDS 20 IE CAN 0001
Coding: 03604
Shop #: WSC 06435
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03140
Shop #: WSC 06325
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 E
Component: Airbag 7 Audi 0304
Coding: 00104
Shop #: WSC 06325
Address 17 -------------------------------------------------------
Controller: 8L0 919 860 C
Component: AB-KOMBIINSTR. VDO D07
Coding: 00042
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0V0178671
Address 35 -------------------------------------------------------
Controller: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk D03
Coding: 13130
Shop #: WSC 06325
Address 45 -------------------------------------------------------
Controller: 8L0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 06325
2 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
31-00 - Open or Short to Ground
01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio D01
Coding: 00201
Shop #: WSC 06325
End -------------------------------------------------------
EDIT: z tego co wyczytałem to są czujniki czyżby te w słupkach ? jak sprawdzić czy są ok ?
