Pokazane rezultaty 1 do 3 z 3
Temat: Błędy vag - mała diagnoza
    redDCcrew's Avatar
    Oct 2008
    Śląsk
    Astra GTC Sport
    Domyślny Błędy vag - mała diagnoza
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 018 C
    Component: 1,8l R4/5V MOTR HS V06
    Coding: 04000
    Shop #: WSC 06325
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 E
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 03604
    Shop #: WSC 06435
    1 Fault Found:
    01276 - ABS Hydraulic Pump (V64)
    16-10 - Signal Outside Specifications - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 D
    Component: A3 KLIMAVOLLAUTOMAT_D75
    Coding: 03140
    Shop #: WSC 06325
    Address 15 -------------------------------------------------------
    Controller: 8D0 959 655 E
    Component: Airbag 7 Audi 0304
    Coding: 00104
    Shop #: WSC 06325
    Address 17 -------------------------------------------------------
    Controller: 8L0 919 860 C
    Component: AB-KOMBIINSTR. VDO D07
    Coding: 00042
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0V0178671
    Address 35 -------------------------------------------------------
    Controller: 8LO 862 257
    Component: ZV-Pumpe, DWA, Funk D03
    Coding: 13130
    Shop #: WSC 06325
    Address 45 -------------------------------------------------------
    Controller: 8L0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 06325
    2 Faults Found:
    01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
    31-00 - Open or Short to Ground
    01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186
    Component: Radio D01
    Coding: 00201
    Shop #: WSC 06325
    End -------------------------------------------------------
    EDIT: z tego co wyczytałem to są czujniki czyżby te w słupkach ? jak sprawdzić czy są ok ?
    Ostatnio edytowany przez redDCcrew - 21-12-08 o 13:13
    Mar 2008
    Mazowieckie
    9 razy
    1378 - Czujnik ultradźwiękowy alarmu, strona prawa - G171
    1377 Czujnik ultradźwiękowy alarmu, strona lewa - G170
    1276 Pompa hydroagregatu ABS - V64
    kisiel66's Avatar
    Jul 2009
    Dębica
    a3
    1.8 AGN
    Panowie, (Panie oczywiście też ) , jeśli wiecie co może być przyczyną błędów związanych z tymi czujnikami ultradźwiękowymi to proszę o jakieś info. Z góry dzięki
