VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 BB
Component: 1,9l R4 EDC 0000SG 2809
Coding: 00002
Shop #: WSC 06435
5 Faults Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-10 - - - Intermittent
17655 - Needle Lift Sensor (G80): Open or Short to Plus
P1247 - 35-00 - -
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019458
Shop #: WSC 06435
3 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
01130 - ABS Operation
008 - Implausible Signal - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 8L0
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900 B
Component: AB-KOMBIINSTR. VDO D11
Coding: 00140
Shop #: WSC 01200
˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0Y1399049
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-10 - Open or Short to B+ - Intermittent
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D14
Coding: 02081
Shop #: WSC 06435
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
End -------------------------------------------------------
