Strona 2 z 4 PierwszyPierwszy 1234 OstatniOstatni
Pokazane rezultaty 11 do 20 z 38
Temat: Centralny zamek A3 8P
  1. #11
    Dec 2014
    Łódzkie
    1.6 BGU
    takie mam błędy czy jakaś podpowiedz z tego wynika co do centralnego zamka? I na co jeszcze zwrócić uwagę? Za pomoc z góry dziękuję jestem początkujący.
    42 44 46 52
    VIN: WAUZZZ8P74A037773 Mileage: 138570km/86103miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    Address 01: Engine Labels: 06A-906-033-BGU.lbl
    Part No: 06A 906 033 BB
    Component: SIMOS71 1.6l 2V 5312
    Revision: 00000003 Serial number: AUX7Z0C6FN70BT
    Coding: 0000071
    Shop #: WSC 12345 111 20238
    VCID: 60C5D124B358BCE
    2 Faults Found:
    19617 - Linear Oxygen (Lambda) Sensor B1 S1; Pump Current Wire
    P3161 - 008 - Open Circuit - Intermittent - MIL ON
    Freeze Frame:
    RPM: 1792 /min
    Bin. Bits: 00100000
    Voltage: 5.020 V
    Voltage: 0.000 V
    RPM: 1440 /min
    Bin. Bits: 00100000
    Voltage: 4.920 V
    Voltage: 0.000 V
    16520 - Oxygen (Lambda) Sensor B1 S2
    P0136 - 006 - Malfunction in Circuit - Intermittent
    Freeze Frame:
    RPM: 2144 /min
    Mass Air / Rev.: 98.1 mg/str
    Bin. Bits: 00100000
    Voltage: 0.320 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0051846
    Shop #: WSC 06435 000 00000
    VCID: 336F6E68522E776
    No fault code found.
    Part No SW: 8P0 820 043 HW: 8P0 820 043
    Component: KlimavollautomatH11 0130
    Shop #: WSC 00000 000 00000
    VCID: E9D34C00C0627D6
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 143
    Mileage: 131682 km
    Time Indication: 0
    Date: 2014.02.05
    Time: 16:48:54
    Freeze Frame:
    Temperature: 12.5°C
    Speed: 11.7 km/h
    (no units): 50.0
    (no units): 165.0
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl
    Part No SW: 8P0 907 279 HW: 8P0 907 279 *
    Component: Bordnetz-SG 1.0 H27 0401
    Revision: 00000000 Serial number: 00000000035724
    Coding: 100C4F0080000000000000000000000000
    Shop #: WSC 00030 259 16938
    VCID: FAF1034CB5C4C6E
    Subsystem 1 - Part No: 8P1 955 119 Labels: 1TX-955-119.CLB
    Component: Wischer WWS Audi350 0130
    Coding: 16711696
    Shop #: WSC 00030
    3 Faults Found:
    00093 - Terminal 15 for Starting Relevant Consumers
    008 - Implausible Signal - Intermittent
    01049 - Supply Voltage Term 50
    012 - Electrical Fault in Circuit - Intermittent
    01502 - Bulb for Rear Fog; Left (L46)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 G HW: 8P0 959 655 G
    Component: Airbag 8.4EDmin H01 0130
    Coding: 0011102
    VCID: 468927BC31BCF2E
    2 Faults Found:
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    010 - Open or Short to Plus - Intermittent
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 007 0030
    Coding: 0000012
    VCID: 30656164A3384CE
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 930 D HW: 8P0 920 930 D
    Component: KOMBIINSTR. VDO H25 0070
    Revision: D04 Serial number: 2246CD04008468
    Coding: 0004103
    Shop #: WSC 55555 111 59537
    1 Fault Found:
    01298 - Instrument Cluster Lamp Test
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 174
    Mileage: 138428 km
    Time Indication: 0
    Date: 2015.01.13
    Time: 11:20:25
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0070
    Revision: 08 Serial number: 17001035095829
    Coding: 3D0F0300070100
    VCID: 2649873C91FC12E
    1 Fault Found:
    00470 - Combination comfort Databus in Single Wire
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 138328 km
    Time Indication: 0
    Date: 2015.01.09
    Time: 19:43:31
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D04 Serial number: AUX7Z0C6FN70BT
    1 Fault Found:
    01176 - Key
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H09 0010
    Coding: 0000048
    VCID: 39735C4070428D6
    1 Fault Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 143 L
    Component: EPS_ZFLS Kl.6 0402
    1 Fault Found:
    00003 - Control Module
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 B
    Component: KSG H02 0030
    Coding: 188800186D288505484A016000
    VCID: 3B7F46487A7EBF6
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    1 Fault Found:
    01565 - Luggage Compartment Light (W3)
    007 - Short to Ground
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 A
    Coding: 0000048
    VCID: 3A71434C754486E
    1 Fault Found:
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    End ---------------------------------------------------------------------
  2. #12
    Jun 2011
    Kraków
    Audi A3
    1.6 BGU
    witam,
    odświeżę temat. w moim Audi, przestał działać centralny zamek, nie działa z pilota, nie działa z kluczyka. sprawa o tyle dziwna że otworzyłem samochód - przejechałem nim 20km - zgasiłem i podczas próby zamknięcia okazało się że nie działa.
    czy mogę prosić o wskazówki - będę sumiennie wykonywał
  3. #13
    wdawid1982's Avatar
    May 2014
    Poznań
    A3 8V
    2.0 TDI - CRLB( 150 KM)
    5 razy
    12 razy
    Na początek diagnostyka vcds.
  4. #14
    Loocash's Avatar
    Feb 2015
    Warszawa
    A3 8P Sportback 1,6 MPI
    A3 Sportback
    1.6 BSE
    Próbowałem dopisać drugi kluczyk - w jednym nie działa pilot. Kupiłem z rzekomo wyczerpaną baterią. Sądziłem, że długo padnięta i się rozkodował.
    I w tym miejscu gdzie się podaje liczbę kluczyków komp przyjmuje mi tylko jedną sztukę - nie akceptuje wartości 2szt. W innym miejscu jest jak widać gdy się klika pilotem - pokazuje mi pilot 1 i przyciski - na drugi pilot nie reaguje. Nie wiem czy tam powinno być widać również ten niedopasowany kluczyk?
    Chyba mam po prostu uwalony pilot. Dioda świeci i bateria OK. Próbowałem tez dopisać ręcznie - jeden w stacyjkę drugim otwierać i guziki wciskać ale nie robiło roboty. Znacie dokładną procedurę dopisania pilota w tym modelu.
    Dzięki z góry.
  5. #15
    Mar 2016
    Gdańsk
    Audi A3 8P0
    1.9TDI AGR
    Hej
    Nie znalazłem zbliżonego wątku związanego z moim zapytaniem więc pytam tutaj.
    Dopiero co zaczynam przygode z Audi A3 8P0 (2004 1.9 TDI). Z przyzwyczajenia z jazdy Golfem 5 często używam blokowania drzwi od środka (guzik przy klamce kierowcy).
    W Audi odruchowo też zacząłem z tego korzystać i np. zauważyłem pewien (dla mnie) problem.
    Stanąłem z odpalonym autem na podjeździe (wcześniej wcisnąłem guzik blokady drzwi od środka) i wysiadłem zamknąć brame. Drzwi kierowcy otworzyły się normalnie za pierwszym pociągnieciem klamki. Wysiadłem i zamknąłem odruchowo drzwi. Zamknąłem brame i kiedy chciałem otworzyć drzwi ... zamknięte. Drzwi zatrzasnęły się. Na szczęście dziewczyna była w środku więc otworzyła mi je i nie było problemu. Czy to normalne zachowanie w przypadku użycia tego guzika blokady czy to jakiś fail ?
    Dzisiaj sprawdziłem, że jak blokuje drzwi od środka to pasażer musi otworzyć drzwi ciagnąc za klamke 2 razy i kontrolka blokady drzwi gaśnie. W przypadku kierowcy otwierają się od razu a kontrolka nie gaśnie i drzwi po ponownym zamknięciu dalej się blokują. Chciałbym wyjaśnić czy to normalne zachowanie czy po prostu drzwi kierowcy nie dają sygnału, że ktoś wysiada i blokada powinna się wyłączyć. Tak było poprzednio w Golfie 5.
    W przypadku kiedy nie używam blokady od środka problem oczywiście nie istnieje.
    Prosiłbym kogoś o odpowiedź
    Jan 2016
    Włocławek
    2.0TDI BKD
    Witam, zaznaczam od razu że szukałem takiego lub podobnego tematu i nic nie znalazłem, Mój problem tkwi w tym że przestał działać mi centralny zamek z pilota (na kluczyk nie działa) nie zamyka ani nie otwiera wcześniej było tak że czasami nie działał ale po przyciśnięciu kilku razy odblokowywał i zamykał teraz nie działa w ogóle bateria wymieniona i nie kodowałem bo nigdy nie musiałem po zmianie baterii kodować zawsze było ok, dostałem się do modułu komfortu i po przyciśnięciu klawisza słychać przekaźnik na module, czyli wychodzi na to że się łączy, ale drzwi się nie blokują, wymieniłem nawet moduł komfortu ale nadal jest to samo (słychać przekaźnik na module) ale nie zamek nie działa. rozebrałem kluczyk ale wszystko jest jak najbardziej ok, czyste i suche, jakieś wskazówki gdzie szukać ?
    nie mam vaga obecnie i brak dostępu..
  7. #17
    Sep 2015
    Gorlice
    2.0 TDI CR CBBB (170KM)
    Witam, mam następujący problem z centralnym zamkiem.. Gdy otworzę drzwi z pilota to otworza sie tylko prawe tylne drzwi, resztę drzwi otwieram ręcznie. Z zamknięciem nie ma problemu. Ktos miał taki przypadek?
  8. #18
    Jun 2016
    Leszno
    Audi A3
    13 razy
    Czy ktoś wie, czy są zamki 10 pinowe? Nie działa mi mikrostyk, wiem już, że konieczna jest wymiana całego zamka, ale podobno mam 10 pinowy zamek a na allegro widzę tylko 8 i 9 pinowe...
  9. #19
    Aug 2010
    Dąbrowa G
    2.0TDI BKD
    127 razy
    13 razy
    Cytuj Oryginalnie napisane przez Xenq Pokaż post
    Nie ma, kiera po lewej od kierowcy 9 pin, od pasażera 7 pin.
  10. Podziękowania dla Mobilek za pomoc w problemie
    Xenq (18-12-17)
  11. #20
    Golem1's Avatar
    Jan 2010
    Pruszków
    Audi a3
    2.0TDI BKD
    253 razy
    15 razy
    Zamek kierowcy obsadzone ma 9 pinów ale wtyczka jest 10 pinowa, pasażera wtyczka 8 pinów a zamek 7 pinów i stąd może tak informacja o zamku 10 pinów.
  12. Podziękowania dla Golem1 za pomoc w problemie
    Xenq (18-12-17)
