Jednak miałem błąd na umowie.
VIN - zacenzurowałem
Spisałem z podszybia.
MAKE AUDI
MODEL AUDI A3
TYPE A3 TDI 1.9 R4 81/EG2M (8L10Y4)
MAKE YEAR 1998
PRODUCTION DATE 08/04/1998
MADE IN INGOLSTADT (GERMANIA)
ENGINE CODE AHF
FUEL DIESEL
LITRES / CCM / DESCRIPTION 1.9 / 1896 CM3 / VEP
POWER / KW / HP / RPM 81 KW / 110 CP la 4150 RPM
TORQUE / RPM 235 Nm la 1900 RPM
CYLINDERS / VALVES 4 CYLINDERS / 8 VALVES
TRANSMISION CODE DEA
PAINT COLOR ALUM SILVER METALLIC (L5 / Y7M)
INSIDE COLOR SLATE (GREY) (DJ)
SPECS
X3A national sales program France
A8S standard equipment
G0C 5-speed manual transmission
K8G hatchback
MF4 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIMVEG 2 base engine is T8U
T8U 4-cylinder diesel engine 1.9 L unit 038.G
0CJ vehicle class differentiation 8L0
0F3 fuel system for diesel engine
0RA without ignition/starter switch locking system
1H0 without proportioning valve
1N1 power steering
1X0 front wheel drive
2C5 axial and vertical adjustable steering column
2LA fuel tank without special material treatment
4P0 rear floor panel module, type 1
7E3 sheathed type glow plug heater
7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve
8M1 rear window wiper and washer system with intermittent control
C05 operating permit, alteration 5
SA7 inventory control model 2
SK9 internal vehicles safeguarding standard production
S8B control of new paint shop Ingolstadt
PDA sports suspension
PR1 Track Setup
WAF equipment package for France
WM3 Sharan "Voyage II" for Belgium / Luxembourg with RCH radio "gamma"
C3F cast alloy wheels 6 1/2J x 16 5-arm style, offset 42
H6U tires 205/55 R 16 91W
N7H Alcantara/fabric seat covering
0AL front stabilizer
0BB rear stabilizer
0TD front and rear floor mats
1GL front shock absorption, sports design 2
1JK rear shock absorption, sports design
1MR four-spoke leather-covered steering wheel
1PC wheel bolts with anti-theft protection (unlockable)
3H6 backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
3L3 height adjustable front seats
3NC split rear seats, double folding, removable
4SD left vanity mirror illuminated
4TD right vanity mirror illuminated
6E3 center armrest front
6Q2 leather gearshift knob/handle
6R2 leather gearshift boot
8BG twin headlamp for left-hand drive with integrated high-beam headlight
9AK automatic air conditioning with sun sensor
9Y1 outdoor temperature gage
B0A component parts set without country-specific design requirement
B99 type approval EC
E0A no special edition
FA0 control of standard production
F0A no special purpose vehicle, standard equipment
J0L battery 340 A (70 Ah)
J23 suspension range 23
KD0 spare parts for Customer Service
L0L LHD vehicle
Q1A standard seats
U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
0A1 two doors
0FA standard manufacturing sequence
0G4 cable gearshift
0LJ special plates/stickers/ safety certificates for France
0L2 electric throttle actuation
0ST labels/plates in German and French
0VB French owner's manual
0YZ without determination of weight categoryfor rear axle
1AH electronic differential lock (EDL)
1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 without towing attachment
1EX VIN plate
1E0 without activated charcoal canister
1G3 alloy spare wheel with original equipment tires
1KK disc brakes, rear
1LR front disc brakes with integrated adapter
1SA without additional engine guard
1S7 tool kit and aluminum jack
1T0 w/o first aid kit and warning triangle
1WB transmission shaft w/ 100mm in diameter
1YA without transmission shafts f. rear axle
1Z0 initial standard fuel filling
2A5 delivery equipment (transit coating) with thin seat cover
2B3 additional exterior noise suppression (hood, capsule and dash panel)
2D1 complete cd enhancing underbody panel
2G8 filler neck module 2 without insert
2JB standard bumpers
2V1 dust and pollen filter
2WA without additional tires
2Z1 type sign at rear and "Quattro" nameplates respectively
3B0 without additional child seat anchor
3C1 static lap belt, center rear
3FA without roof insert (standard roof)
3Q1 rear headrests
4A0 without seat heater
4E0 tailgate/trunk lid unlocking from outside
4GH windshield tinted with windshield sunshield
4K1 radio remote controlled central locking
4L2 dipping breakaway inside rear view mirror
4M0 without cup holder
4R1 power windows
4UE airbag f. driver a. front seat passenger
4W0 without cassette and CD storage unit
4X1 side airbag front
5C0 without special body measures
5D1 Remote control and central locking system
5E1 without sill top with door cover
5J0 without rear spoiler
5K1 paint preservative (wax)
5RQ outer right rear view mirror: convex
5SL left wing mirror: non spherical
6M0 without tie down straps/net/pocket
6N0 without mud flaps
6PA plastic hand brake lever handle
6V1 rear trim panel (ECE)
6W5 front license plate bracket
6XC outer rear view mirrors: powered
7AA electronic vehicle immobilization device
7A0 without CD changer/CD player
7CB label for radio remote control
7M0 plastic scuff plates in door apertures
7P0 without lumbar support in front and rear seats
7QA without CD ROM
7Q0 without navigation device
7X0 without park distance control
8CC speedometer sensor without seal (electronic speedometer sensor)
8GL alternator 120A
8KA w/o catalytic converter warning light
8K0 without special low beam mode
8N4 windshield wiper intermittent control with potentiometer (four speeds)
8Q1 headlight-range adjustment
8RE Four (passive) loudspeakers
8S5 two reading lights front
8TC rear fog light for driving on the right
8T0 without cruise control system (CCS)
8UB radio preparation
8WA without front fog light
8W0 without washer fluid level indicator
8X0 without headlight washer system
8Y1 two-tone horn
8Z5 engine cooling system, type 1
9D0 without preparation for two-way radio installation
9P0 without seat belt warning light
9Q0 without multi-function indicator/ on-board computer
9T1 heated washer nozzles, front
9W0 w/o car phone preparation/installation
9X4 without heated door lock cylinder with micro switch
