Kilka błędów od klimy:
Centralna elektryka:Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 L HW: 8P0 820 043 L
Component: KlimavollautomatH16 0200
Revision: 017978 Serial number: 8P0820043L
Shop #: WSC 06314 000 00000
VCID: 356A238A631B60B4
3 Faults Found
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 219
Mileage: 59910 km
Time Indication: 0
Date: 2011.08.01
Time: 14:51:10
Freeze Frame:
Temperature: 22.5°C
Voltage: 12.20 V
RPM: 12750 /min
Load: 0.0 %
Load: 0.0 %
01592 - Air Quality Sensor (G23
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 219
Mileage: 59910 km
Time Indication: 0
Date: 2011.08.01
Time: 14:51:17
Freeze Frame:
Temperature: 26.5°C
00796 - Fan for Interior Temp Sensor (V42)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 60066 km
Time Indication: 0
Date: 2011.08.13
Time: 17:03:14
Freeze Frame:
Voltage: 10.90 V
Temperature: 28.5°C
Poduszki powietrzne:Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002012154
Coding: E18C5F80C014100000181800180000000028FE175C1100
Shop #: WSC 06314 000 08192
VCID: 4084425E2CD9D51C
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00150573
Shop #: WSC 06314
3 Faults Found
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 61
Reset counter: 222
Mileage: 59392 km
Time Indication: 0
Date: 2011.07.07
Time: 12:05:00
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 222
Mileage: 59392 km
Time Indication: 0
Date: 2011.07.07
Time: 12:05:00
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 58
Reset counter: 222
Mileage: 59392 km
Time Indication: 0
Date: 2011.07.07
Time: 12:05:00
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
Wie ktoś jak pozbyć sie tych błędów?? Samo kasowanie nie pomaga bo po jakimś czasie wracają. Generalnie to da się z nimi żyć ale wolałbym aby było czysto po skanie. Klimatyzacje przeważnie mam wyłączoną , tylko od czasu do czasu włącze aby schłodzić wnętrze auta i przełaczam na Econ. Wydaje mi się że klima działa OK. Rok temu na lato miałem odgrzybianą i napełnianą czynnikiem. Także kontrolka airbag mnie dobija. Czasem sie zapala troche poswieci i sama gasnie. Zauważyłem że gdy mocno popada i pojeździ się po kałużach częsciej sie zapala i swieci. Jak jest sucho generalnie jest ok. Za info serdecznie dziekujęAddress 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H10 3250
Revision: 91H10325 Serial number: 0035W0005B5I
Coding: 0032605
Part No: 8P0 910 339
Component: BF-Gewichtsens. 01 0020
Coding: 00032605
1 Fault Found
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 31
Reset counter: 25
Mileage: 59433 km
Time Indication: 0
Date: 2011.07.10
Time: 09:30:12
