Thursday,03,November,2011,18:24:17:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P... Mileage: 201770km/125374miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 J HW: 028 101 138 3
Component: R4 1,9L EDC 0000SG 5497
Revision: 12345678 Serial number: AUX7Z0C9FNO03O
Coding: 0000071
Shop #: WSC 06435 000 00000
VCID: 2A5000F6BAA53F4C
1 Fault Found
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 000 - - - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 38.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 11000000
Temperature: 81.0°C
Duty Cycle: 9.6 %
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
VCID: 336E1D926D6F7E84
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 002079 Serial number: 8P0820043E
Shop #: WSC 00000 000 00000
VCID: 2E580CE6864D536C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl
Part No SW: 8P0 907 279 HW: 8P0 907 279 *
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000231652
Coding: 0088CF0082141000000000000000000000
VCID: FAF070B68A85CFCC
Part No: 8P1 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
VCID: 458A534A33FBF034
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 009 0030
Coding: 0000002
VCID: EFE651E2C1C79A64
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 900 D HW: 8P0 920 900 D
Component: KOMBIINSTR. VDO H27 0110
Revision: D07 Serial number: 1249CD07009272
Coding: 0004003
Shop #: WSC 00012 000 00000
VCID: 3064129E9C79459C
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 24001039053C92
Coding: 3D0F0B42070100
VCID: 2648F4C6AEBD1B2C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D07 Serial number: AUX7Z0C9FNO03O
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 39722FBA4F0384D4
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
VCID: 2D5A0BEA8B4B2874
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 008800186D288505484A016000
VCID: 3B7E35B2453FB6C4
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001062871
VCID: F0E4529EDCF9859C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A7030B64A058FCC
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3C1598766
Coding: 0001001
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B5E05F2B55F2644
End ---------------------------------------------------------------------
