; VAG-COM Measuring Block AGU Engine Label file.
; Component number 06A 906 018 CG
; Does not work with 06A 906 018 FA (2000 US 2.0L)
1,0,Basic Functions - Spec figures at Idle
001,1,Idle speed,800-920 rpm
001,2,Engine load,0.5-1.5 m/s
001,3,Throttle ang,0-5 deg.
001,4,Ignition ang,6-12 BTDC
2,0,Basic Functions - Spec figures at Idle
002,1,Idle speed,800-920 rpm
002,2,Engine load,0.5-1.5 m/s
002,3,Inj. period,1.00-3.00 m/s
002,4,Air mass in,1.8-4 g/s
3,0,Basic Functions - - Spec figures at Idle
003,1,Idle speed,800-920 rpm
003,2,Supply volts,10-14.5V
003,3,Coolant temp,80-105 d/C
003,4,Intake temp,-45-108.5 d/C
4,0,Idle Stabilisation - Spec figures at Idle
004,1,Throttle ang.,0-5 deg.
004,2,Idle mass,-1.7-1.7 A/T
004,3,Idle mass,0 if man/t
004,4,Op. mode,
5,0,Idle Stabilisation - Spec figures at Idle
005,1,Idle speed,800-920 rpm
005,2,Spec. idle,860 rpm
005,3,Idle reg,-10-10%
005,4,Air mass in,1.8-4 g/s
6,0,Idle Stabilisation - Spec figures at Idle
006,1,Idle speed,800-920 rpm
006,2,Idle reg,-10-10%
006,3,Lambda reg,-10-10%
006,4,Ign angle,6-12 BTDC
7,0,Lambda learned values
007,1,Lambda reg,-10-10%
007,2,Probe volts,0-1V
007,3,Valve duty,angle 0-99%
007,4,Correction,0.3-1.25
8,0,Lambda learned values
008,1,Inj. period,1-3 m/s
008,2,Idle learned,-10-10%
008,3,Learned,-8-8%
008,4,Vent mode
9,0,Lambda learned values
009,1,Idle speed,800-920 rpm
009,2,Lambda reg,-10-10%
009,3,Probe volts,0-1V
009,4,Idle learned,-10-10%
10,0,Fuel tank breather
010,1,Valve duty,angle 0-99%
010,2,Correction,0.3-1.25
010,3,Filter state,-3-32
010,4,Purge rate,0-0.3
11,0,Fuel Consumption
011,1,Idle speed,800-920 rpm
011,2,Engine load,0.5-1.5 m/s
011,3,Road speed,km/h
011,4,Consumption,l/h
12,0,Fuel Consumption [Not verified in manual]
012,1,Engine rpm,0-6800 rpm
012,2,Voltage,V
012,3,Consumption,l/h
012,4,Ign degrees,deg
13,0,Knock regulation [Not verified in manual]
14,0,Knock control
014,1,Engine speed,0-6800 rpm
014,2,Engine load,0-10 m/s
014,3,Cyl 1 retard,0-9 degCA
014,4,Cyl 2 retard,0-9 degCA
15,0,Knock control
015,1,Engine speed,0-6800 rpm
015,2,Engine load,0-10 m/s
015,3,Cyl 3 retard,0-9 degCA
015,4,Cyl 4 retard,0-9 degCA
16,0,Knock control
016,1,Sens 1 volts,0.4-1.4V
016,2,Sens 2 volts,0.4-1.4V
016,3,Sens 3 volts,0.4-1.4V
016,4,Sens 4 volts,0.4-1.4V
17,0,[Not listed in manual - Using default labels]
18,0,Altitude adaptation
018,1,Idle speed,800-920 rpm
018,2,Engine load,0.5-1.5 m/s
018,3,Throttle,valve angle
018,4,Alt. correc.,-50-10%
19,0,Additional signals
019,1,Engine speed,0-6800 rpm
019,2,Engine load,0-10 m/s
019,3,Additional,signals
019,4,Ign. timing,20Atdc-42Btdc
20,0,Operating Modes
020,1,Idle speed,800-920 rpm
020,2,Auto trans,Neutral/ON
020,3,Air cond.,AC High/Low
020,4,A/C Comp.,Compr ON/OFF
21,0,Lambda Control
021,1,Idle speed,800-920 rpm
021,2,Engine load,0.5-1.5 m/s
021,3,Coolant temp,-40-125 deg/C
021,4,Lambda mode,
23,0,Throttle valve adaptation
023,1,Learning req.,100000
023,2,Min stop,72-95%
023,3,Emerg. stop,60-91%
023,4,Max stop,18-54%
24,0,Knock control
024,1,Engine speed,0-6800 rpm
024,2,Engine load,0-10 m/s
024,3,Ign timing,20Atdc-42Btdc
024,4,Sum of ret.,angle 0-36
25,0,Charge Pressure control
025,1,Spec. load,3-8 m/s
025,2,Load correc.,0-8 m/s
025,3,Actual load,0.5-8 m/s
025,4,Valve cycle,0-99%
26,0,[Not listed in manual - Using default labels]
27,0,[Not listed in manual - Using default labels]
66,0,Cruise control
066,1,Road speed,km/h
066,2,Switch pos.,xxxx
066,3,Spec. speed
066,4,CCS switch,position
95,0,Basic functions
095,1,Idle speed,800-920 rpm
095,2,Engine load,0.5-1.5 m/s
095,3,Ign timing,
095,4,Coolant temp.,80-105 degC
97,0,[Not listed in manual - Using default labels]
98,0,Throttle Valve Matching/Calibration/Adaptation
098,1,Valve voltage,0-5V
098,2,Sender voltage,0-5V
098,3,Opr. mode,
098,4,Adapt mode,RUN/OK/ERROR
99,0,Lambda regulation
099,1,Engine speed,0-6800 rpm
099,2,Coolant temp,-40-125 deg/C
099,3,Lambda reg.,-10-10%
099,4,Lambda mode
;End of File
http://hostuje.net/file.php?id=fa9a4...45cccccda9d6a7
