Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P54A004674 Mileage: 272020km/169025miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0010SG 9884
Revision: 12345678 Serial number: AUX7Z0C3FN905W
Coding: 0000072
Shop #: WSC 00750 259 99051
VCID: 2757E54596F6351
3 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11000000
Temperature: 11.7°C
Bin. Bits: 10110000
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 -
Freeze Frame:
RPM: 1008 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11000000
Torque: 132.0 Nm
Bin. Bits: 1 01 0
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
Freeze Frame:
RPM: 798 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000111
Temperature: 74.7°C
Temperature: 60.3°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0023174
Shop #: WSC 00011 000 00000
VCID: 336F0115522E491
No fault code found.
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0120
Shop #: WSC 00000 000 00000
VCID: E9D3237DC062431
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V15
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 21
Reset counter: 42
Mileage: 267893 km
Time Indication: 0
Date: 2014.01.05
Time: 10:20:00
Freeze Frame:
Voltage: 14.40 V
Temperature: 19.5°C
(no units): 220.0
(no units): 226.0
Temperature: 5.0°C
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 14
Mileage: 270733 km
Time Indication: 0
Date: 2014.01.23
Time: 11:36:11
Freeze Frame:
Voltage: 8.30 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006087602
Coding: A1885F0082141000000000090000000000
VCID: 3B7F29357A7E811
Subsystem 1 - Part No: 8P1 955 119 Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0110
Coding: 16711696
Shop #: WSC 00000
5 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
02395 - Parking Light Right Front (M3)
02394 - Parking Light Left Front (M1)
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Shop #: WSC 06435 000 00000
VCID: 458B4FCD0CBAC71
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000012
VCID: 30650E19A338729
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 C HW: 8P0 920 930 C
Component: KOMBIINSTR. VDO H24 0050
Revision: D02 Serial number: 2243CD02001872
Coding: 0004103
Shop #: WSC 12345 259 01234
VCID: 32610411AD34409
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 00000011
Fault Priority: 6
Fault Frequency: 16
Reset counter: 244
Mileage: 271147 km
Time Indication: 0
Date: 2014.02.01
Time: 19:39:19
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 38
Reset counter: 43
Mileage: 271149 km
Time Indication: 0
Date: 2014.02.01
Time: 19:45:22
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H07 0040
Revision: 07 Serial number: 15000133271237
Coding: 3D0F0B42070100
VCID: 2649E84191FC2C9
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D02 Serial number: AUX7Z0C3FN905W
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8P0 959 801
Component: Tuersteuerger. H08 0010
Coding: 0000048
VCID: F8F576398BC8EA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 143 K
Component: EPS_ZFLS Kl.6 0308
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0020
Coding: 008800186D288505484A0160
1 Fault Found:
01179 - Incorrect Key Programming
000 - -
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8P0 959 802
Coding: 0000048
VCID: F9F3733DB0C2F31
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V14
005 - No or Incorrect Basic Setting / Adaptation
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1851482
Coding: 0001001
Shop #: WSC 31013 264 81958
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 11
Reset counter: 32
Mileage: 265961 km
Time Indication: 0
Date: 2013.12.19
Time: 20:20:33
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
Component: PTC-Element 0303
Revision: 00400000 Serial number:
VCID: 2953E37D80E2031
End
